for months ive been trying to wrap my head around this. Right now I have keepalived working flawlessly on two nodes. sharing one failover ip. Essentially running pihole or equivalent services and if the pid goes down it pushed the IP to the second node. Reading that CARP is essentially the same thing I fail to understand why it doesn’t work the same. When i try to make to VIPs for the shared ip lets say 10.0.0.1 (one master one slave) it fails and says the ip is in use. Can someone just tell me if this is possible and if so what I am I doing wrong. Everything i read is about wan and i just want to implement this failover on a vlan hoepfully without using HAproxy just carp Thanks
keepalived.conf
vrrp_instance pihole_failover {
state MASTER
interface lan0
preempt delay 5
virtual_router_id 55
priority 200
advert_int 1
unicast_src_ip 10.0.0.2
virtual_ipaddress_delay 10
unicast_peer {
10.0.0.3
authentication {
auth_type PASS
auth_pass redacted
virtual_ipaddress {
10.0.0.4/24
track_script {
keepalived_check
