I bought a 2nd UAP-AC-M and want to install this as a wireless mesh AP, The idea is that I connect a Unifi Switch US-8 to bring the network into a 2nd building.
While I am trying to setup the 2nd AP as a Meshed AP, I am not able to have this working.
I can adopt and configure the 2nd AP when connected via wire. but once I bring it outside it stays in isolated mode or disconnect mode. The 2nd wireless mesh AP is connected via the POE power brick and I can see the status led in blue. It doesn’t matter if I configure this AP with an static IP address or use DHCP the status isolated.
I also tried to adopt the 2nd AP wireless, but this does not proceed and I is stuck in the status: ADOPTING| WIRELESS
What about minimum RSSI settings? Be sure they’re set to be off, also, be sure to set the 5 GHz channel and power to Auto on at least the second unit, if not on both. Also, try putting the units within 10 or 20 feet of teach other to see if they issue is one of distance / interference. You can also try limiting the 5 GHz channel width to 20 MHz or 40 MHz to avoid possible interference issues.
