Few months ago I bought a new system for my pfsense:
https://staging-forum.lawrencesystems.com/t/perfect-homelab-low-priced-pfsense-box/14476/8?u=gerard
I configured a 2 port LAG port and set my 7 vlans as trunk over this lagg0 interface.
This works beautifully for local traffic between vlans.
The problem i have is with the wan. I have high ping times, video en audio streams are constantly disturbed.
I contacted my ISP they tested and measured my cable modem for 7 days and concluded there is nothing wrong with the modem and/or Internet connection.
So the problems should probably be within my own network.
While searching I found and used Tom’s video below and set that up.
I did what Tom is explaining in this video.
I have btw ipv4 and ipv6
I can’t select both gateways in de floating rule so i made 2 floating rules and use the same limiters for both IPv4 and IPv6.
Wen i test it is not working. Ping times are still crazy high.
I looked over the settings several times and don’t see any difference between Tom’s settings and mine besides 2 floating rules for IPv4 and IPv6
I don’t understand why it is not working.
