I would use DNS blocking with IP exclusions so the unrestricted users can still access everything else. You should be able to permit the IPs in the DNSBL config. I would also NAT all outbound DNS traffic to your pfSense LAN IP so it forces all DNS queries to your firewall.
I am new to pfsense; I have been looking for that option to exclude IPs (Alias: Unrestricted) on pfblockerng DNSBL (also tried the pfblockerng_devel version) but with no luck. Could you confirm that this option is there and if you could elaborate more.
One simple method, since you have staic IP’s for these users is to create 2 alias’. One for the domains you want to block (youtube and facebook). The second are the IP’s you want to block these domains from. Make a block rule on the interface you need and this would stop them.
That was what I tried before, it works on facebook. It also works on “youtube.com” but not “www.youtube.com” even if I add “www.youtube.com” to the FQDN list. If my users search google for youtube, they will get the “youtube.com” search result and so they cannot access it. But if they type www.youtube.com in the browser’s address bar, then it works.
Then simply add www.youtube.com to your alias. It should update the IP’s.
Edit:
Running a DNS query shows these results.
Resolved IP addresses of "www.youtube.com": ["172.217.0.174","142.250.190.46","142.250.191.206","142.250.190.110","142.250.190.142","172.217.4.46","142.250.191.174","142.250.190.14","172.217.2.46","142.251.32.14","142.250.191.142","142.250.191.238","142.250.191.110","172.217.5.14","142.250.190.78","172.217.1.110","2607:f8b0:4001:c66::5b","2607:f8b0:4001:c56::5b","2607:f8b0:4001:c66::be","2607:f8b0:4001:c56::88"]
Resolved IP addresses of "youtube.com": ["209.85.145.190","209.85.145.91","209.85.145.93","209.85.145.136","2607:f8b0:4001:c01::be","2607:f8b0:4001:c01::5b","2607:f8b0:4001:c01::5d","2607:f8b0:4001:c01::88"].
I wanted to share my recent success with AdGuard Home. After some consideration, I decided to try out AdGuard Home so I install Raspberry Pi Desktop on a used computer and run AdGuard Home on it. I then configured my pfSense DHCP settings to point to AdGuard Home’s IP address, allowing me to handle all DNS-based content filtering there.
I’m extremely pleased with AdGuard Home, it provides everything I need (and more!) with remarkable ease of use.
As an extension, I also implemented this setup on my home network by installing AdGuard Home directly on my Synology NAS, and also redirect dns from my routers dhcp setting to my Synology (AdGuard) ip address. It works great.
Highly recommend giving it a try if you’re looking for an efficient ad-blocking and DNS filtering solution for FREE.
I wish AdGuardHome could run straight on pfsense in the future.
