Hi there!
My Backblaze B2 cloud credentials fail authenticate on TrueNas CORE 12. It used to work correctly but has stopped after I switched from an ISP provided router to pfSense. I then decided to test out Amazon S3 after failing to find a fix with Backblaze and ran into a similar issue.
The errors i receive in the TrueNAS GUI are when authenticating the cloud credentials are:
Backblaze:
Error: 2022/02/07 00:36:34 Failed to create file system for "remote:": failed to authorize account: failed to authenticate: Get https://api.backblazeb2.com/b2api/v1/b2_authorize_account: dial tcp: lookup [api.backblazeb2.com](http://api.backblazeb2.com) on [::1]:53: read udp [::1]:30631->[::1]:53: read: connection refused
Amazon S3:
Error: 2022/02/07 00:29:47 ERROR : : error listing: RequestError: send request failed
caused by: Get https://s3.ap-southeast-2.amazonaws.com/: dial tcp: lookup s3.ap-southeast-2.amazonaws.com on [::1]:53: read udp [::1]:31817->[::1]:53: read: connection refused
2022/02/07 00:29:47 Failed to lsjson with 2 errors: last error was: error in ListJSON: RequestError: send request failed
I -think- the issue is related to me not configuring something correctly in pfSense as the issue wasn’t present before switching. It’s a fresh install without any add-ons.
Couldn’t find a fix after a quick search online, however if the issue has an existing solution then I’d really appreciate being pointed in the right direction.
If any of you wonderful people need further information, I’m more than happy to provide it. If I’m being an idiot, I’m happy to be told as much, haha.
