Checking with you all (especially users that work within an AZURE environment), if you could point me in the best direction…
As you know with Windows, there is this app that installs that application
As we connect to WVDs to run our desktop in the Azure cloud.
On linux, I have to use the WEB link interface, but I wanted to see if there was an app for Linux. If you know or use, please let me know.
I am not looking to remote on to the server (like an admin)… Several Websites state using XRDP or something like I would using MSTCS. As you know the Remote Desktop takes them into their user profiles setup on WVDs and lists the groups they are assigned to… like this…
If I use the WEB link, it get the samething, but what I wanted to make use of was that the app allows multi monitor usage and maps your DEFAULT printer on your desktop and your local C drive and other attached map drives, that I am not getting on the WEB link side.
