I would like to move away from Authenticator Plus, does anyone have any recommendations? I would like to be able to import my authplus.db if at all possible.
I am using https://getaegis.app/ which works really well but it can not natively import from Authenticator plus. But you can export an HTML with QR codes from Authenticator plus that you can scan back in.
Thanks! I got out my android device, the iPhone app didn’t have those settings. Thanks for your help, worked like a charm.
