APC BX1500G UPS Madness - ups stuck in on/off loop if usb cable connected
Ref: https://community.se.com/t5/APC-UPS-for-Home-and-Office-Forum/Back-ups-XS-BX1500G-switches-to-battery-and-shuts-off-when-USB/m-p/315440
It’s a long thread with no solution. Uncertain of the original date.
Tl;dr scenario
  1. Mains power disconnected
  2. NUT/APCUPSD shuts down server and orders UPS to power down - server takes 10s to power off
  3. 60s after #2, UPS powers off (but not completely*)
  4. Few seconds after #3, mains power is restored
  5. This is where things get weird. Ups powers back on, providing power to the battery outlets, but at the same time, UPS is running on battery (by the sound of the fan)
  6. If this is allowed to continue, ups will turn off again in 60s, regardless if OS has booted, pulling power immediately. This loop continues indefinitely
  7. The only way to stop the loop is to leave mains disconnected for an additional 30s after ups has shut down (note the * in #3). When #3 happens, the button leds remain lit for those 30s. Once they go out, ups is fully shut down.
In the real world, this is an unlikely but not impossible scenario - that is typically server is configured to initiate shutdown after x time on battery (5, 10 min to conserve battery life). The chance of power coming back on exactly 90s after initiating power down would be an unlikely coincidence, but again not totally impossible. Power outages when they do happen around here typically require manual intervention by the electric company to reset the breakers on the poles.
Still, this is something that should not be happening. The UPS should kill power to all outlets until it (the ups) has FULLY shut down and reset. Such is the behavior of a cyberpower unit I have.
This unit works well otherwise and has recently (within the last 18 months) replaced batteries.
If there’s no other workaround then the only other option is to configure the NUT software to NOT power the ups down. Leave it be, until either power is restored or batteries run down.
Thoughts or ideas?
