Any reason not to get the USW-Pro-HD-24-PoE over a USW-Pro-Max-24-PoE
Probably getting a USW-Pro-HD-24-PoE.
Besides the more expensive cost, any reason to get the USW-Pro-Max-24-PoE instead? Looks like the HD is better in every way over the Pro Max.
Look at the tech specs for each switch - UniFi Cloud Gateways - Tech Specs and decide which one fits your requirements now and in the future
Hey, I have looked at all specs already which is why I was saying it looks better in every way.
Just wondering if there’s something hidden (a gotcha) that I’m not aware of.
That link you sent is much better for comparing specs than the sales page side of the site, thanks!
The HD is only $200 more, has a higher power budget, 2.5G ports, but has 2 less 10G SFP+ and two 10G RJ45 so it comes down to your needs.
I don’t think that’s correct Tom, from what i can see.
The HD is more expensive, has 22 x 2.5G ports and 2 x 10g ports, as well a 2 extra (4 in total) 10G SFP+ ports, along with 200W extra PoE budget.
Yes, I fixed my comment above. (I was a bit tired but still typing)
All good. Probably go with the HD as it’s better all round specs-wise. It’s just out of stock in EU for the past week.
