I need advice on two possible UniFi small network configurations, it would be very helpful as I don’t have enough expertise to determine which one and why. I’ve read all sorts of opinions, but none of them were backed up by facts; more or less everyone was just defending some personal opinion without supporting it with any concrete information. Even that the UDR7 built in switch is somehow inferior in quality to Flex switches (not meaning the missing STP) .
Background; I have the Dream router UDR7 and 2 x wired Express7 - UX7 access points. Two VLANs, one DEFault (native) and one IoT VLAN. The IoT VLAN is on 2.4 GHz only and transmitted only by UDR7, with only one IoT device. Nothing else. Two firewall zones, DEF and IOT all set and working.
So here are the two possible configurations:
UDR7 is the router, WAN is on port 4, the port 5 (SFP+) not connected.
To each remaining UDR7 ports (1, 2 and 3) are connected three 5-port Flex Mini 2.5G switches (one next to router and two in different rooms). To those switches are connected the end devices and the 2 AP’s (obviously one switch doesn’t connect an AP). I assume that this configuration won’t have STP issues. Maybe the STP can be switched off? -
UDR7 is the router, the ports 1,2 and 3 are disabled, WAN on port 4 and the port 5 connects via 10Gb DAC cable to a (non PoE) Flex 8 switch next to router. To this switch are connected some end devices, two 5-port Flex 2.5G switches to which are connected the two APs and other end devices. Obviously from devices and switches I won’t get a connection speed higher than 2.5 Gb to UDR7. In opesite direction except the short DAC cable is also 2.5Gb.
Which configuration and why to choose?
