Dear Community,
as some maybe already know, I try to take care of the IT infrastructure of my brothers small landscaping company. I was tasked to setup create a “good” network. So I went full on Unifi. (there is a TL;DR at the end).
The setup was:
Side A (main office):
LTE Modem (150/20 Mbit/s - static IP) -> USG -> Unifi 24 Switch
Side B (remote site):
LTE Modem (40/10 Mbit/s - static IP) -> USG -> Unifi 8 Switch
I configured IPSec VPN Access for my brother and me. I also made a tunnel between the sites. On the remote site we have only one workstation and one printer.
I was not very happy with the connection time and so was my brother. Additonal I didn’t like the installation routine for IPSec in Windows 10. Therefore I switched the VPN Access to the Syonology OpenVPN.
Additional I had some problems on the remote site. I had to change the LTE Modem to a Mikrotik LTE6 Modem to get the full bandwidth. Managing the USG and switch without the controller (main side) was not the best experience. (Still have an issue but this will be an other thread).
After all these changes I thought I would be finished. By brother still complaint about problems to open en small Excel file from home. Then I saw a video from “how to test VPN encryption types with iperf” - I did the same and found out, that when I connect to the Synology VPN the speed drops down to 0,2 Mbit/s.
That was the point were I took my testing workstation set up pfsense and installed it at the main site. OpenVPN runs now as accepted.
But I like to have my test workstation back. Therefore I like to buy hardware for pfsense (even I just saw the untangle video
TL;DR: I am thinking on buying following hardware for different sites:
- Main site - LTE 150/20 Mbit/s - Services: Road Warrior VPN, Site-to-Site tunnel -> SG-2100
- Remote site - LTE 40/10 Mbit/s - Services: Site-to-site tunnel -> SG-1100
- For my home: SG-2100 (because of 4 LAN ports)
Do you thing they are sized correct? I am in Europe so I have shipping cost. Are there reseller in Europe?
Or should I go for other hardware?
Thank you.
