Hi everyone, I’m in need of some advice.
I’m in the process of looking for/buying a new house.
When moving into the new house I would like to upgrade my current network setup.
In my current home which has 3 layers (ground, 1st and 2nd) and is all reinforced concrete, I’ve always had issues with getting good/strong wifi signal all around the house.
Last year I purchased Ubiquity Amplifi (wifi5) Mesh system which improved things a lot.
However in the new house I would like to take it to the next level.
So I plan on placing a PFSense box as firewall/router and purchase a new managed network / Mesh wifi system.
For the switch(es) I was thinking of stepping up the network to using VLANS.
I would like the Mesh wifi system to have the additional ability to use wired backbones opposed to the Amplify system that can only use wireless backbone.
so planned lay-out would look like this:
GroundFloor: CABLE MODEM ---- PFSense ---- switch (4port) ---- WiFi AccessPoint
1st Floor: WiFi AccessPoint (probably not cabled, but signal is strong enough for 2 bedrooms and bathroom) ---- maybe additional wired connection to the tv connecting to switch on ground floor
2nd: switch (8port) connecting to GroundFloor ---- WiFi AccessPoint (wired backbone) ---- 2 servers ---- 2 laptops ---- 1 workstation
What products would you advice, especially for the Wifi AccessPoints???
Unifi??? Mikrotik??? other
