I just got a uni dream machine pro. Sometime soon i want to add a poe switch. I know to adopt it but how do i extend my vlans to the second switch? Sorry for brong a newbie
@Trilback - No “noobie” questions, only “noobie” answers ![]()
Once you adopt your new switch into the controller - I’m assuming it will be a Unifi as well - the VLANs will be propagated to the switch(es) as well. The port you use to connect from the Dream Machine to the switch should be set to “All” as should be the uplink port on the new switch. You can then assign the other ports on the switch to whichever VLAN(s) are required.
