Hello Everyone!
New here, and I am trying to setup pfSense with my Actiontec T3200.
- Actiontec T3200 and pfSense works great with RFC 1483 via DHCP.
- RFC 1483 Transparent Bridging on the T3200 and pfSense doesn’t get a WAN IP or internet.
What am I missing to get this to work with the T3200 in bridged mode?
Please help.
I can get the modem into transparent mode no problem. I am sure the failure of the WAN port on pfSense is just settings I am not sure about how to set it up.
I have the same setup as the Actiontec is needed for TV service. When I set the transparent bridge mode it did not work right as you have discovered…it didn’t disappear off the network (became a true transparent bridge) as it was supposed to so I determined that the ISP provided firmware disabled that functionality.
What I did was I created a DMZ on the Actiontec (under firewall), which did work, to the IP address of PfSense. This gave me full PfSense functionality. If you setup a VPN be aware that the generated IP address by the VPN wizards will have the internal PfSense address and you have to edit it to be the real WAN or I use a DDNS address in case the WAN IP address ever changes…it hasn’t in over 3 years.
