What is the best way to add 2 FA to the Pfsense admin login? I’ve looked at several articles and it seems that it shouldn’t be that complicated. My Synology nas was a checkbox as are most other setups. I was hoping the new 23.01 update would provide such a solution but apparently not.
First, pfsense should only be accessible on a trusted internal network and restricted to only allow certain IP’s which can be considered a second factor of authentication. Another option would be to use the Radius package. Solved: Two factor authentication for admin login | Netgate Forum
Thanks Marin for the response. I’ve read the post and watched several videos. It seems that they are all related to FreeRadius and VPN authentication. I want to have 2FA for the management interface. It seems that there should be an easy straightforward way to accomplish that . Any way to include it in the next update as part of the initial setup?
