Looking to rent an adjoining office space and connect the existing network rooms.
Can I simply replace switches on each side with something like Cisco Systems SG250X-24 24 Port GB Smart Switch 10G Uplink and run Cat6A cable (amazon.com/Cable-Matters-Snagless-Shielded-Ethernet/dp/B00HEM6C7C) between? Network rooms are approx 175ft apart.
Any alternative switch recommendations? Would like to stick with Ethernet for the 10G as I am more familiar with and have tools. A 16 port would be sufficient but didn’t see any with 10G Ethernet uplink.
Thanks for the recommendations, and sorry for not being clearer, but the existing wiring on both sides is gigabit Ethernet. I wanted to upgrade to a switch with a 10G copper port to link them. Would the Cisco I found above work?
Run a 8 or 12 strand singlemode (OS2) fiber between between them. The “speed limit” of singlemode fiber has yet to be found, so it is very solid investment
Not sure how big each space is and how much MDF/IDF distribution you’re doing at each site, but if you’re able to spend the capital now, you could do something like this https://www.fs.com/products/29123.html and have 40Gbps between sites and 10Gbps distribution at each site.
