Hi
Thank you for all your suggestions. I really appreciate all the help.
I“m a bit confused about all the different things like the dongle that“s inserted into the sfp? switch. Do I need dongles to insert into the network card to use common network cable?
Depending on the length of cable needed, there are copper cables with an SFP type plug integrated into each end those tend to be no longer than 3 meters I (think?). These are sometimes referred to as Direct Attached SFP copper.
SFP are simply media converters allowing either a copper SFP port or a fiber port (for much longer runs), the electronics on these determine what speeds it will handle. SFP ādonglesā are only relative to SFP enabled switch gear.
If you buy SFP enabled switch gear make sure you buy a supported SFP type, some switches are specific about what they will or wonāt support.
None of this relates directly to a thunderbolt product, unless you are going to use some type of thunderbolt to ethernet adaptor. Apple is notorious for not letting itās devices interact with anything it deems incompatible or unsupported (same thing).
Cal Digitās thunderbolt adapter is not SFP enabled. If you are not going to use any media except for copper just skip SFP gear entirely.
I prefer 4 ports, channel bonding at least 2 of those ports into one virtual ethernet cable is a nice option to have.
Startech makes a 2 port for 280-ish.
I used to source what they call āworking pullsā from ebay, basically network cards pulled in working condition from machines being overhauled. They were sold at super cheap prices typically.
Hi
I“ll stick to the easiest solution there is. Just a network cable without any dongles or special connections. Will this NIC do the job as I intent it for in a truenas solution? Directly connected into my mac thru a Thunderbolt to 10 Gbe link?
Is it supported?
I appreciate your tips & your time very much. It helps he alot to get backup from my mac mini.
In this case I did everything with RJ45 ethernet as itās easier to work and likely something youāre familiar with already, vs SFP+ optics or DACs which are normally used with switches and servers as opposed to consumer gear.
Youād connect the TB3 dongle to your Mac, this will act as a network adaptor. Install the 10g card into your TrueNAS box. From there, plug a CAT6/6A cable from the TB3 dongle into the 10g port on the switch, as well as another CAT6/6A from the TrueNAS box to the 2nd 10g port on the switch. Connect the switch to your main network, either via another switch or your router, depending on your setup.
Both of these connections would be your main connections for both devices to your network.
Iām not familiar with that specific model, but it looks like it uses an Intel X550 which would be supported fine with TrueNAS.
You can directly connect your Mac (via the TB3 adaptor) to the TrueNAS box and skip the switch altogether, but youād need to setup static IP addresses in a different subnet than your normal network.
IE: if your network is 192.168.2.0-254 youād want to put the IPs for the 10g links in say 192.168.100.0-254, this way the traffic between them will go over the 10g links instead of the 1g links. This will only work if you use the IPs on the 10g links, if you connect to the IP of the 1g link, youāll get 1g speeds.
This issue is why I recommended a switch as it simplifies the configuration slightly since you no longer need to utilize static IPs for the 10g links.
Your problem may not be network speed, I commonly move terabytes and never need to wait more than 4 -5 hours, even if it is a lot of small files. Small files take more time than large things like contiguous video files (sort of). And all I have is gigabit to the clients. Iād take a look at what your throughput is and see if it is close to wire speed. You should be able to get 900mbps (100+MBps) unless the bottleneck is somewhere else, or you are moving thousands of small text files and pictures. When moving thousands of small files, I may only get a quarter of the speed depending on the files. A 10gbe connection between server and client may not help much with things like this.
Somehow I glossed over the ā10s of gigsā, must have read TBs or something else.
What is the config of the TrueNAS box? CPUs, disks, RAID configuration, etc.
Run an iPERF test between the Mac Mini and the TrueNAS box
For TrueNAS, either SSH into the server or in the GUI go to Shell, run iperf -s to start the server. On the Mac, download iPERF 2, Iām not 100% on Mac instructions but the command is ipefc -c [server IP]
On the server you should see the network speed the 2 can communicate at, below is what mine looks like. The first result is what you should see running at 1gbe, the 2nd is 10gbe.
Hi Greg. I tried to move an photo library wich is about 900 Gb over and I think the NIC on the motherboard reset itself a few times or the file is just to big.
I`ve ordered an thunderbolt 3 to 10 Gbe adapter and a 10 Gb nic for my truenas. Hopefully I can take a full backup
Thank you for your reply & suggestions
I really apriciate all input on this topic
OK, so thousands of āsmallā files, yes that might take a long time, and it is very likely that 10gbe wonāt fix anything. Really need to know if you are transferring at maximum speeds or not. Copy some nice big video files over, stuff over 4 gigabytes and see how long that takes, even better if you can get a real speed metric like from the FreeNAS pages to see how much bandwidth is being used during these transfers.
Now if there is a hardware fault too, then that is something that needs to be addressed.
Also what is you disk configuration, data transfer is a two sided thing, if you have a slow drive on either side it doesnāt matter how fast the network can move the data. We get that when we move video files from our cameras to our storage, the SD cards only go as fast as they go.
Yet if I move those same files from server back to local hard drive they move pretty good (lots of database files go with the clips). If I take a large export from a video project, moving this is fast, same with zipped files and I normally āsaturateā he gigabit connection going to each client. I was able to do that when the server was on gigabit, 2 gigabit (aggregated), and now 2 10gbe (aggregated). While 10gbe to some clients would be nice, it just isnāt important to what most people are doing for a lot of different reasons. The number of people working with uncompressed video is relatively small and certainly needs fast storage too.
