After changing the management network to different nic and reboot xcp-ng server I lost console access. This happened to me twice. I had to reinstall the server. Console does not show up in xcp-ng center neither in xen orchestra. All VMs consoles are fine.
Any idea how to fix it ?
Are you able to SSH into the management IP after the switching to a different NIC?
Although a long shot, what if you disconnect the server from XCP-ng Center, and re add the host?
Yes. I am able to ssh to server.
I did re add host. no luck
Only other thing that comes to mind is restarting the toolstack. Right click on your host, and choose restart Toolstack. However, if you’ve tried to reboot the host since the problem started, that would effectively do the same thing.
