So I’m sure I’m just having a dumb moment but I can’t for the life of me figure out to delete physical interfaces in XCPNG - either via XOA, XCPNG Center, or the console.
Basically what I did was I had a 4 port 1 gig intel NIC in this box at one point in time - i’ve since removed it, yet it’s still hanging out in the config. I have also swapped from a 10 gig Chelsio NIC to a 10 gig Intel NIC as well. I’m all the way up to Eth10 with only Eth0 (onboard) being correct.
Ok I guess I didn’t get it fully sorted out. I cleaned up the mess I’d made with the swapping of NICs and not removing them, however I think I got too zealous with my cleanup.
I tried running the emergency network reset from the console but that didn’t seem to help the situation either. I’m sure I’m missing something stupid easy but I can’t figure it out. I have a link light on the 10 gig NIC so I don’t think it’s a hardware issue.
