I would like to create a virtual xcp-ng network dedicated to database communication between my 3 hosts. and also create a separate lab to mess about.
Could anyone please tell me how to do that?
Do I have to select a ‘physical’ NIC Interface or can I leave it blank?
So far I selected ‘Private network’ nas I am not sure what to choose for Encapsulation.
There is an option to create the network as which will allow communication between VMs once a static IP is set on the VM. IP has to be manually set unless you attach a DHCP server to the internal network. External communication won’t occur unless you attach a VM running pfSense or something similar to that network.
I needed very basic functionality so that’s how I did it.
