Xcp-ng on ryzen 3600
Hi
When I try to install xcp-ng latest version on an AMD ryzen 5 3600 system, there is a kernel panic and the system reboots. What could I be doing wrong ?
Instead of posting images, post the text from them as it will help with searching, specifically the error message “iommu_init”
Also try using the latest 8.3
Yes, seems like the same issue I had with my Ryzen 9 5950X. I think the other option if you still prefer to run 8.2 for now is to turn off SR-IOV in the BIOS.
https://staging-forum.lawrencesystems.com/t/xcp-ng-8-3-beta-anyone-running-it/18671/5?u=retrorenovations
I’ve been having problems getting XC-PNG to install as well. I’m using a ryzen proc on MSI motherboard. I currently do not have IOMMU turned on, should that be on or off?
