I am looking at getting a UniFi protect but have a couple of questions.
There is both a ethernet and an SPF+ port. Can both be used at the same time with different IP addresses?
There are 4 drive bays. How many drives do you need to make the system work? Will it work with only 2 drive bays used?
Do I need a cloud key if I only want the video to be seen from the local network?
