I just upgraded to the latest Ubiquiti network application 9.4.17.
As usual, the coding gurus at Ubiquiti have moved the SSH credentials info page from the usual places to somewhere else that I simply cannot find.
If anyone has any insights as to where in the interface the SSH credentials can be found in version 9.4.17, please share….
Other than that the application upgrade process went well and everything else works as expected.
OK I will reply to my OWN post on this…
YES typical that as soon as I post the question, the answer becomes self evident..
Prior to this release they moved the specific device settings to a little icon next to the top right corner of the gui.. That has been removed..
To get to the device settings…
Click on the UNIFI DEVICES icon in the left menu , EXPAND the pop out menu , Click the Device Update and Settings link…
That will bring up the familiar window onthe right side of the GUI where you will find the all the details as expected.
Cheers
