TrueNas Scale: 25.04.: adding vlan doesnt work
Hi guys
I just successfully upgraded my system to TrueNAS SCALE 25.04 (via 23.x and 24.04.x). Now I’m in the process of reinstalling my apps.
My Goal: I want to assign dedicated IP addresses to my apps (e.g., Grafana) like 192.168.1.51.
My Problem: Every network change I attempt fails during the “Test Changes” step and gets reverted.
What I’ve tried so far:
  1. VLAN Attempt: I followed the Lawrence#S guide (https://youtu.be/P6WrEp64qzg) to create a VLAN for the apps. As soon as I configure the new VLAN interface and click “Test Changes,” the changes are reverted after 60 seconds.
  2. Attempt to Switch to Static IP: I also tried to disable DHCP on my main network interface. However, when I edit the interface, uncheck “DHCP,” and then click “Test Changes,” this also fails and reverts.
My Network Configuration:
  • Router: pfSense
  • TrueNAS IP: 192.168.1.10 (currently assigned via DHCP reservation from pfSense)
  • Gateway: 192.168.1.1
  • Desired App IP: 192.168.1.51
What is the correct procedure to switch from a “DHCP reservation” to a “Static IP + Alias” without the “Test Changes” step failing?
Thanks for your help!
some screenshots:
grafik
grafik3359×990 179 KB
My router ip is configured in the global configuration correctly, i think
grafik
Are you adding the IP after you uncheck DHCP and setting it to the network settings as 192.168.1.10/24
My primary network interface is currently configured to use DHCP. To assign a static IP (or set up a VLAN), I need to uncheck this option - as seen in your great video :slight_smile:
However, any attempt to apply this change fails. Whether I only uncheck the DHCP box, or if I uncheck DHCP and add a VLAN in the same step, the result is the same: the ‘Test Changes’ step fails, and the configuration reverts to DHCP.
I can’t help without knowing the answer to this.
btw:
the issue was exact that. i had to uncheck dhcp, enter an alias, test, and commit the changes. just unchecking dhcp, testing is reverting the changes.
classical error between keyboard and chair :slight_smile:
