Hi,
I would like to build a small lab network for running Docker containers and virtual machines in order to experiment with a PLC that provides an OPC-UA data stream. The PLC is fixed to the 100.127.250.0/24 network, and I cannot change this IP range.
I already have a Cloud Gateway Max and an HPE MicroServer Gen10. My plan is to install XCP-ng on the HPE to host the various tasks (VMs, Docker, etc.).
I’ve watched Tom’s videos on similar setups, but I’m still a bit uncertain about the best way to handle the PLC and its network range. Specifically:
- Should I connect the PLC directly to the HPE MicroServer?
- Should I connect the PLC directly to the Cloud Gateway Max?
- How should I plan the network design (IP ranges, VLANs, etc.) to access the PLC’s data stream effectively?
Any guidance or suggestions would be greatly appreciated!
Inspiration from GitHub - lawrencesystems/Draw_IO_Diagrams: Diagrams used in my YouTube Videos
