I have a new pfsnese build but my routing logs are getting flooded buy “radvd 40776 sendmsg: Permission denied” about every 10 seconds. Can anyone help figure out how to stop this from happening.
Try disabling IPV6, that solution has solved that in other posts
In System > Advanced > Networking
Allow IPv6 is unchecked
IPv6 over IPv4 is unchecked
Prefer IPv4 over IPv6 is checked
IPv6 DNS entry checked
As far as I know that is turning off as much IPv6 that I can think of, is there something I am missing?
Make sure under services you have both the DHCPv6 Server & RA & DHCPv6 Relay off.
Just checked both DHCPv6 and DHCPv6 Relay is turned off. Unfortunately still this in the routing logs
|Aug 7 03:07:16|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:07:24|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:07:30|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:07:37|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:07:44|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:07:52|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:08:01|radvd|40776|sendmsg: Permission denied|
|Aug 7 03:08:10|radvd|40776|sendmsg: Permission denied|
Weird, might want to try the Netgate forums https://forum.netgate.com/ as it’s not an error I have had before.
Ok, thank you for trying. Great place you have here. And your videos are really the best! Thank you for all you do.
I noticed this error also in the new RC build.
Solution: go to Services -->DHCPv6 Relay → tab Route Advertisment and there disabled it.
The error message wil stop.
