Hello, I am new to Pfsense Firewall. May I ask, if is it really necessary to have 2 public static IP? One is for WAN and the other for LAN?
Thank you.
Thank you.
The WAN is usually dynamically assigned by your ISP. Unless you paid extra for a static. I’ve had no issues with the defaults from the setup process.
The LAN is your internal network. There you would need to set a static IP. Usually it would look like “192.168.x.1”.
