well, the nextcloud instance run as a docker container and uses the default http setting on port 80, i have redirected the port within docker from 325 (dockerhost) to 80 (container)
yes, http://192.168.166.10:325 works right away. but not from the outside. And the host has not even a firewall active right now, not even the ufw is active.
HI
I have the same problem.I have installed nextcloud in podman pod with postgresql and nginx . I access nextcloud locally ot my network on port 8443 but can’t get ssl through PFsense HAproxy with my domain name. Тhat’s my only problem. I have quite a few other applications that run through PFSENSE’s Haproxy natively. I’m using a wildcard certificate, but I don’t know where the problem could be.
there are others with this problem but i followed everything they did. DNS resolver, backend and frontend …and etc. Could the nginx.conf configuration be the problem, please someone who has ideas to share how to make it work properly.
That looks like the server that HAProxy is not getting a response from your Nextcloud, look at the logs in NextCloud and see what is coming from HAProxy.
