i have a side - side VPN with two fritz.box modems. On one side is a pfsense box connected to the modem.
I Have two LAN networks configured on the pfSense box. When I try to ping a host on the other modem it only works from the second LAN network, not from the first.
Do you have any idea what it could be?
I opened the firewall with an any-any rule on both LANs but no luck. I can’t find the difference in the two networks ?
Client — Router A ----------VPN --------- Router B ----- pfSense ------LAN 1 & LAN 2
I can see the web interface of the client from the router B and the pfSense LAN 2 but not from LAN 1.
I looked up all the settings, but could find the difference of the two Subnets.
@neogrid I use for now any-any rules to test it. I can’t see any blocking in the logs.
