Apologies if this is a duplicate post as I have seen other posts similar to this but haven’t been able to find the answer to my problem. When logging in or navigating to the dashboard it is super slow and I feel that it is a DNS issue but seems like I have everything set up correctly. I have a custom domain name set up on pfSense on port 10443 with a Let’s Encrypt certificate. I have also checked the DHCP Registration option under the DNS Resolver to register my host name in the DNS Resolver. Nevertheless, it is still super slow (takes 1-2 minutes to navigate to the dashboard) and not sure how to fix this. Any help would be appreciated!
Yeah I had this on my box, when I removed the Firewall logs widget it was refreshing normally.
