I have pfsense setup in a typical HA with a /29. I am trying to use the CARP to bind to openvpn server and it looks like it is working because the secondary pfsense box has the openvpn services down which is expected per the documentation
https://docs.netgate.com/pfsense/en/latest/vpn/openvpn/ha.html
for whatever reason I am unable to connect if I am using the CARP address but if I set it to the WAN address it works fine. What am I missing here?
The socket shows that its bound to the right port but if you test the port it shows as closed.
