Lluke
1
Hey Guys,
I would like to open a specific port for all pfBlocker Geo-IP lists. What would be the easiest way to do that?
I hope it’s understandable. I want to keep the Geo filtering but if someone try to access a specific port it shouldn’t be blocked / filtered.
Thanks and happy Easter
Rules work from top down so you can create an allow rule about the pfblocker rule.
Lluke
3
Thanks for the fast response and btw the awesome YouTube videos
I’ve done that on WAN and floating.
I pushed the allow port XYZ to the top of the floating rules but it went to the bottom unfortunately.
Lluke
4
I created a second floating rule on top and it stays there for now. I’ll restart the firewall later and see if it stays there.
In pfblocker -> IP section towards the bottom “Firewall ‘Auto’ Rule Order” will need to be set so tthe pfblocker rules come after your rule.
