I am not very good at finding out how to fix my problems
I am using freenes 11.2
nextcloud 17
and I have errors the 1st one is I am trying to update my nextcloud and I get this
The following places can not be written to:
- ./usr/local/www/nextcloud/updater/…/.htaccess
I can find where this is to fix it
next I get these
There are some warnings regarding your setup.
PHP does not seem to be setup properly to query system environment variables. The test with getenv(“PATH”) only returns an empty response. Please check the [installation documentation ] for PHP configuration notes and the PHP configuration of your server, especially when using php-fpm.
MySQL is used as database but does not support 4-byte characters. To be able to handle 4-byte characters (like emojis) without issues in filenames or comments for example it is recommended to enable the 4-byte support in MySQL. For further details read [the documentation page about this]
Accessing site insecurely via HTTP. You are strongly advised to set up your server to require HTTPS instead, as described in the [security tips ]
the docoumts on these that the link has is for other os freenes is different it has jails and I can figure out how to fix it
then I get this in Nextcloud
Invalid private key for encryption app. Please update your private key password in your personal settings to recover access to your encrypted files.
I change the password but nothing happends and I can find out how to fix it
and the last thing
how do I get webdev to work with windows out side my network nextcloud tells me to use this
.Free classifieds - yourdomain.com.
the nextcloud instruction in nextcloud is using https do I need to setup ssl to make it work out side my network or is there a work around that I can setup in my router or freenes
or how do I set up nextcloud to make it work
please help and thank you
