All. I am having fits trying to get something to work and I am not sure if it is possible or how to get it working. Before anyone tries to critic the “why” I am doing this, I want storage access running on my 40G networks, inter-app traffic running on the 10G networks, and web traffic running on the 1G network. I have valid reasons for what I am doing and the approach I am trying to take. Please keep replies to the subject at hand, “How can I share a single directory over different subnets so that the traffic runs at the speed of the subnet the share is suppose to be mounted to.” If their is a better way to accomplish my goal then I am all ears but it must address my specific known requirement.
I have three servers each with a single directory that I want to share to the other two servers. Each server is multi-homed with a single 1Gbe, 2x 10Gbe, and 2x 40G IPoIB connections. I have added routing tables and subnets for the 10G and 40G connections and let the 1G connection use the default routing table. Traffic flows correctly across each subnet properly. So I believe the networking and routing is done correctly.
When I try to mount the host directory across any subnet other than the default 1G subnet on one of the client computers I can not see the directory. Is this possible? The OS is Proxmox so it is using a modded Debian 10 kernel.
NFS Host Server File: /etc/exports
/share01 172.20.100.0/24(rw,fsid=0,sync,no_root_squash,crossmnt,no_subtree_check)
/share01 172.20.110.0/24(rw,fsid=0,sync,no_root_squash,crossmnt,no_subtree_check)
/share01 172.20.120.0/24(rw,fsid=0,sync,no_root_squash,crossmnt,no_subtree_check)
/share01 172.20.130.0/24(rw,fsid=0,sync,no_root_squash,crossmnt,no_subtree_check)
/share01 172.20.140.0/24(rw,fsid=0,sync,no_root_squash,crossmnt,no_subtree_check)
NFS Client Server File: /etc/auto.master
/- /etc/auto.server01 --timeout=0
NFS Client Server File: /etc/auto.server01
/server01/share1G -fstype=nfs4,rw,soft,intr 172.20.100.10:/share01
/server01/share10G01 -fstype=nfs4,rw,soft,intr 172.20.110.10:/share01
/server01/share10G02 -fstype=nfs4,rw,soft,intr 172.20.120.10:/share01
/server01/share40G01 -fstype=nfs4,rw,soft,intr 172.20.130.10:/share01
/server01/share40G02 -fstype=nfs4,rw,soft,intr 172.20.140.10:/share01
I should get the following:
NFS Host ---------------------------------------------------- NFS Client
/share01 ---- 172.20.100.10 (1G)-----------------------172.20.100.20 mount /server01/share1G
|-- 172.20.110.10 (10G)---------------------172.20.110.20 mount /server01/share10G01
|-- 172.20.120.10 (10G)---------------------172.20.120.20 mount /server01/share10G02
|-- 172.20.130.10 (40G)---------------------172.20.130.20 mount /server01/share40G01
|-- 172.20.140.10 (40G)---------------------172.20.140.20 mount /server01/share40G02
