FYI: There seems to be a compatibility issue If you have Keybase loaded but even not connected CISCO Any Connect will not work properly. Am looking at a pcap for further info and am filing a bug report with Keybase. Once you quit Key base CISCI VPN works fine. This true even with a different login on the client via another console, could also be a memory space issue.
