Hi!
Can any one recommend a good IP rule sets that I can use in pfSense to block unwanted IPs? I’ve been looking on FireHol and boy there’s a lot to choose from. Can any one recommend that can be considered as best practice?
Thanks
Hi!
Thanks
Best practice would be to use pfblocker to automate the process.
Thanks TOM! Based on your practice which among IP filters would you recommend?
I’m also running Suricata. What would be a good practice so pfblocker and suricata can co exist? No redundancy or conflict with one another
Suricata is traffic inspection and pfblocker is rules based blocking so they work fine together. The default pfblocker feeds are fine.
