How-To: Self Hosting by Hiding Your Home IP with a VPS + WireGuard Relay (Keeping Real Client IPs)
I only use Cloudflare for my public web sites, so I am OK from a privacy concern. Anything that I host that truly needs privacy I access via Tailscale. And to riff on the old commercial, Tailscale is so easy, even my wife can do it. LOL
i tried the same thing with a cheap vps and wg relay. it kept the real client IP in my logs and fail2ban worked fine. downside is you still have to maintain the tunnel and the home router rules (my router needed a static route). cloudflare is simpler but you lose that control
what control do you lose with Cloudflare?
one of the main issues with CF is that they control the cert and private key so that they can decrypt all your traffic. That to me is a non starter.
That hasn’t been my experience. I put a Let’s Encrypt certificate on my Wordpress VM using certtbot, and that is the same certificate I see when I log into the website from an outside network.
not if you proxy the traffic instead of DNS only as you presumably doing now. If you want to hide your IP you have to proxy it.
No, it’s proxied. It has to be proxied, I am using a tunnel.
i am not sure how you are seeing your LE cert and not the CF edge cert? Are you accessing the web service the same way everyone else would or are you using split DNS and accessing it directly bypassing CF?
No split DNS. Take a look at the cert yourself and see what you see: https://www.leeannperugini.com
The only guess I have is that I have a FQDN for the VM, inside my network of www.leeannperugini.com, and in the tunnel configuration, I am pointing the external domain at my internal domain, using https
It is coming from google on the outside, but internal devices will most likely reach the site on the internal IP address which will hit your proxy or web server.
Right so that’s the CF edge cert which means that you are somehow bypassing CF when you access it thus the LE cert that you are seeing. Most importantly that means that CF is decrypting your traffic on their end and able to examine your traffic.
