@LTS_Tom Liked your how you got started video. I also know the partner problem not quite the same story but when the partner decides not to show up for months…
What I am curious about is how you select contractors in other cities?
The vetting process is hard but I try to take the time to get to know them and check references. It’s not a simple process but they are most often referred from mutual friends which makes it a bit easier.
Yup referrals are the best start but at times doing OSINT is the way to go. Look for specialists wire installers, rack and stack, VoIP, pen testers, those not in direct competition.
