Homelab certificate gendanken
Hello.
First Post so wanted to first shout out to Tom and all the fine staff, Patreon folks, customers, etc that make all this possible. What a great, practical, resource you have created here. You are all to be commended.
And on to the actual post…
I have seen the videos that use pfsense, ACME, and haproxy with wildcard certificates for accessing local resources seamlessly. This is a neat solution however I would prefer to have SSL termination done from end-to-end.
I am trying to decide from a security perspective which is the better route:
  1. generate all the certs in one place (possibly pfsense but maybe a separate instance or container just for this) and distribute the certificates to all the hosts they need to go via ansible.
  2. generate the certs on the devices directly with certbot or however I can interact with ACME API and risk having keys that can modify your entire zone in multlple places on your network.
I don’t mind doing the certificate distribution manually but I also don’t think I can find a better solution than just generating a cert for each host specifically and take the API key risk. I guess you could have different API keys for the DNS provider for each host so that you could invalidate one quickly and not affect everything.
I don’t have any external services to contend with in the case of my homelab but I do want to have a separate DNS zone, even if just in name with local-only DNS resolution.
Does anyone have any better ideas or is there something obvious I am not considering?
Thanks!
Happy to be here :slight_smile:
Eddie
A reverse proxy such as HAProxy in pfsense is an easy way to handle it.
Sorry if my post is too wordy. I tried to indicate I was aware of this solution.
Is there a way to do end-to-end with haproxy?
From what I was getting with SSL offloading the TLS tunnel would be terminated at the firewall and be un-encrypted from the firewall to the server.
Granted that is on a local private network with presumably switched networking, etc but is unencrypted and if any router hops are involved could provide opportunity for sniffing.
Have each server use a self signed cert between the proxy and that server then it would be encrypted. Just make sure you don’t have the proxy validate that cert.
I missed that part in the video. Thanks. I would still like a bullet-proof way to have the cert on the device itself but I totally get your approach and the reasoning.
