I’m trying to configure HA proxy on my SERVERs VLAN to expose services locally.
The problem I have is that port 80/443 are already used by the firewall web interface.
Even if I create a new virtual IP this seems to be automatically bound to the web interfaces too.
Is there a way to create an IP which I can use for HAProxy that will listen on port 80/443 without conflicting with the firewall?
I figured I could create yet another VLAN and just disable the firewall from listening on this, but this seems like an overly cumbersome way to go about it.
Thanks. I tried this, but because each virtual IP is automatically being bound to the firewall it seems to listen on 80/443 which causes HA Proxy to fail.
I think Toms solution is the one that would work.
However, having looked a little closer I wonder if NAT is the issue. I have a NAT with destination “this firewall”. I wonder if this includes my virtual IPs and if I disable this rule only explicit IPs will respond.
So looking at the way it works, the webUI is bound to an interface(s) and it appears that the IP being bound to the same interface responds as with the webUI also.
I think the simplest solution would be either to change the port, or I could disable the webUI on that particular interface (e.g. only listen on LAN).
I note that Opnsense has an option for “allow service binding”.
