What is everyone using for GEO IP Blocking? I used Edgemax routers, but there is no GEO IP Blocking in this router that I can see. I see a lot of people are using pfsense, but I have never tried pfsense.
Justin
Justin
pfsense with pfblocker is how we handle it
I was hoping Ubiquiti would implement this feature in Edgemax. I guess I will need to dive into pfsense. Thank you for your time.
This is the lack of features issue I have with their firewalls. They work great, they are secure, but they lack features.
Yes I agree. I love there routers, just no features. I will probably shoot over to Netgate to pick one up. Thanks again for your time.
I used to manually maintain lists when I was running EdgeMax routers (I still have one as a cold spare) but I have since moved on to OpnSense and really like it. I have it set to only allow the US in unless it is an established/related connection. Yes I know that leaves “infected machines” in my network able to call home but I figured it was a decent compromise because it means I can get to sites like Manjaro.org (hosted in Germany).
If EdgeMax would just add some more features such as GeoIP I would consider going back to them. They really are a solid product, just missing some features (as Tom alluded to)
It’s interesting that the USG has GeoIP filtering and the Edge line doesn’t. I don’t think you’ll regret getting a Netgate device. I switched from a USG to pfsense and don’t miss the USG.
