FreeNAS Build Will these cards work?
Hi all
I’m looking at building myself a new FreeNAS system, I’m wondering whether anyone has used one of these cards with FreeNAS or knows whether they would work?
https://www.ebay.co.uk/itm/4-Port-PCI-SATA-RAID-Controller-Card-Extension-Adapter-with-2-Sata-Cables-AC1264/152988487518?epid=2289394057&hash=item239ed30f5e:g:y8sAAOSw99Ra14IN
Why this card? Because it supports JBOD, I’ll do ZFS within FreeNAS itself so don’t necessarily need a Full-fledged RAID Card.
Thoughts? Suggestions?
Thanks
Might work, but honestly I would go for something more recent.
Looks like this not even PCI Express, just PCI. It only supports SATA 1,5 GBit/s, none of the newer and faster SATA standards. And it might not support drives with a capacity of more than 2TB.
I can recommend LSI 2008-based cards, they set you back around $30 (used) and can be flashed into so-called IT-mode (initiator-target) which disables all RAID cabapilities and makes it function like a plain old HBA. Some of them even allow for SAS/SATA Expanders, letting you connect up to 256 drives to one card.
Exactly the response I was looking for!!!
Thanks
If I picked up one of the LSI cards where would I find the IT firmware?
I think that depends on exactly what model of card you get. I myself bough an IBM ServeRAID M1015, and I got my instructions and download link from this site. You might be able to find the original firmware on the Broadcom support website (under “legacy products”, likely).
Thanks, I may have one of those IBM cards I’ll have a look around the office.
Thanks
