Running 9 stable on two FreeNAS boxes, same configuration.
I have tried using rsync to update the hot backup box from my main server. I am getting only the directories. No files are copied. I have tried all the options in the setup for the push to the backup server, but no files.
I set up the push task and set up a matching module on the receiving server.
I run the task manually from the GUI. I do see drives flashing on both machines but when I check, no files.
Was this a bug in 9 stable (9.10.2-U6) or am I just really screwing up the options?
