can you post some screenshots, your address for the source should match your LANS network CIDR
sure ill just be a few minutes
also i do ifconfig on command prompt and it shows my lan 2 link as up. however on my physical box I know have no green light on the cable connected to a computer, not sure why
Have you enabled those interfaces in pfsense?
Have you done a check to see if the lan1 is using the VPN properly?
when i got a ip check site it always shows my vpn address. speed is normal and all working fine. anything else i should try?
i had enabled previously and also re did the interface assignments to make sure they are selected correctly just yesterday.
Also thank you kindly for helping me
so to confirm i enabled the lan2 physical interface in pfsense software and when connected directly to the box. should be working but isnt for some reason
Can you ping the firewall from lan2
I will have to try later. have to do a few things right now.
Thank you again for the help. I will play around a bit more and post later
the problem i think is the lan2 port or something configured in the lan2 settings. I do not get a green light from the cable connection. therefore no internet. not sure why as ipconfig shows up, shell on the box shows up. i am kinda lost at this point
So i can ping the ip address from my main machine on Lan1
If i goto the computer that lan2 is connected i cannot ping anything and cannot access the pfsense webportal either
I get no light on the pfsense box when i use port 3 or 4. tried to set lan2 to either of those and no change. However according to the interface in the pfsense shell and the webportal both show LAn2 up
i am kinda stumped at this point
In my logs i show this under system-routing
Feb 28 15:41:59 radvd 55510 sendmsg: Permission denied
hundreds of these messages
Thats all the really stood out to me however I am not that experienced
So started with a fresh install of pfsense and all worked. I must have had a setting somewhere limiting me
Thank you all for the help!
