we live in a condo, so dont have the ability to do whatever i want, just enough to get by…
i have a garage that doesnt have an ethernet connection and no way to install one.
powerline wont work.
and it is way too far to use my own wifi.
I DO have access to the buildings ‘public’ wifi.
is there any way, using tailscale or otherwise, to connect a camera via that public wifi to the rest of my system/recorder? unifi would be ok, or any other poe camera (i have both unifi and a separate nvr currently)? if i have to put another pfsense firewall there that would be ok (but a cheap one would be best, since i would only put a camera and my own wifi there, both fed via the public wifi.)
thoughts?
