Chelsio N320E SFP+ card not working with 10Gtek RJ45 transceiver
Hi everyone,
First of all, thanks Tom for your videos, I have learn so much watching them.
Now I’m quite new to SFP(+) cards and transceivers. Based on a older video of Tom, I decided to buy a Chelsio N320E. I end up buying a Chelsio CC2-N320E-SR (came with 2 optic transceivers). I also bought a 10Gtek ASF-GE-T SFP RJ45 transceiver.
I tried the card and the transceiver in a Linux Mint computer and a Win 10 computer. While the card is detected, the computers believe the cable is unplugged!
Can anyone confirm if the 2 assumptions I made are true :
• I can use any type of transceiver (Optic, DAC or RJ45) in a SFP+ card?
• I can use a SFP transceiver in a SFP+ card?
Thus the question, should this combo work?
Thanks
While SFP will usually work in SFP+ not all cards or switched support all SFP/SFP+ modules. Many cards won’t support fiber optic cables at all. The UniFi and MikroTik switches seem quite flexible for supporting modules but companies like Cisco are much less so.
Thank you Tom, it seems that it is a little bit of a gamble to find compatible hardware in the SFP world. Well at least in the used market :wink:
