Hi all,
I have a Centos 7 server that I inherited (I’m not a centos guy) . And the /dev/mapper/cl-root is almost full.
I’m I right in saying that /dev/mapper/cl-root is the root partition, ie where /bin /etc and /var live?
Just need a sanity check
Hi all,
Try a df -h, that should clarify things for you. This is what my CentOS 7 looks like. So my root partition is
/dev/mapper/centos-root
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/centos-root 14G 5.6G 7.8G 42% /
This may answer your question no reason to re-invent the wheel https://unix.stackexchange.com/questions/204413/dev-mapper-in-fdisk
Sorry apparently forums are hard…
Thank you both, make a lot more sense now
