Has anyone setup BGP using edge routers or a SG5100 PFsense/
Yes. What are you trying to do?
Replace a 7026 and cat switch with an edge router 12 ideally, since I don’t need that many ports. Do you have a sample config for the edge router 12?
how do we privately message on this forum? I tried contacting your website.
It’s not just you! cloudberryit.com is down.
can you email me anakaoka @ trinet-hi.com
