Hi there
We have been assigned a /23 ip block and I would like to assign these ips to vms running on the lan. The current setup is as follows:
wan switch: pfsense wan, router from isp
lan switch: pfsense lan, vms
The ISP router has been assigned xx.xx.84.1
Pfsense wan has been assigned xx.xx.84.2
I am able to add network interfaces to the vm which are connected to the lan and wan switches.
Could you explain what I need to do in order to assign xx.xx.84.6 to the vm and allow all inbound and outbound traffic? The vm should also be seen as xx.xx.84.6 and not xx.xx.84.2 (pfsense wan ip).
Many thanks!
